[Gdal-dev] MODIS Equal Area Sinusoidal projection
Jose Luis Gomez Dans josegomez at gmx.net
Fri Jun 2 06:31:35 EDT 2006
Hi!
The MODIS HDF files for level 4 (and up) products are given using the "Equal Area Sinusoidal Projection". I have tried to select one dataset, and export it to a GeoTIFF file using GDAL, but the projection information does not seem to work.The output GeoTIFF file does have the right metadata, thre resulting raster is not properly reprojected. I have also tried to set the source projection with "+proj=sinu", but this does not seem to produce a good result.
What I want to do is to extract one dataset from a MODIS HDF file, reproject it to UTM and then cut an area of interest. However, without dealing with the projection issue first.
Any pointers would be very appreciated!
Many thanks,
Jose
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
      Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
