[Gdal-dev] Re: [mdb-dev] Invalid soname
Mateusz Loskot mateusz at loskot.net
Mon Jun 5 12:16:37 EDT 2006
Jeff Smith wrote:
> --- Mateusz Loskot <mateusz at loskot.net> wrote:
>>As you can see, MDB Tools libraries have invalid soname.
>>Accordint to odbcinst.ini definition of MDB driver, I had to create symlink:
>>$ ln -s /usr/local/lib/libmdbodbc.0.0.0 /usr/local/lib/libmdbodbc.so.0
>>Is this known issue or I did something wrong?
> Yes, this is a known issue with 0.6pre1, which shipped with a bad ltmain.sh.
> Option 1: go to source directory, run 'libtoolize -f -c', then rerun
> configure/make/make install.  Option 2: use mdbtools from CVS.
Jeff,
Thank you for your explanation.
It's clear.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
