[Gdal-dev] raster image preprocessing problem.
Zhonghai Wang zhonghaiw at gmail.com
Tue Jun 6 06:34:54 EDT 2006
Hi there,
I have a couple of GIFs with wld files, but the original Projection is not
the one I want, I tried to use the Proj4 to reproject them on-the-fly, but
it takes really long to perform the map request, therefore I tried
to preprocess the images with GDAL tools, but I've got some problems here:
1. problem with gdalwarp: trying to mosaic the images into one output file,
but only the first image has the correct image color, the other images are
rendered with strange colors, is this a common problem if using gdalwarp to
mosaic images?
2.problem with gdal_merge.py: after trying the gdalwarp command, I've tried
the gdal_merge.py command to merge all the images together with the -pct
parameter, unfortunately, the merged image is the same as the first try. is
it possible to merge images using the command with the correct color table?
BTW: I can not use the gdal_translate command, since there are gaps between
the reprojected images.
thanks for your info.
zhonghai
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060606/37f7ada6/attachment.html
