[Gdal-dev] Problem with Gdalwarp
Tue Jun 6 10:08:45 EDT 2006
[ESW] Jan B. wrote:
> Now, when I try to use the gdalwarp.exe  with
> gdalwarp -t_srs \"+proj=utm +zone=11 +datum=WGS84\" source.tif target.tif
> I get the error
> ERROR 1: Too many points (441 out of 441) failed to transform,
> unable to compute output bounds.
> I am searching for the problem now for 5 days and cannot find it.
Jan,
I'm not sure how the code you included relates to the above command.  Was
it used to prepare "source.tif"?   I downloaded the target.tif you provided,
and it is odd in that it has a geographic coordinate system, but projected
coordinates - fairly small projected coordinates which don't look like UTM
coordinates anywhere in Europe.
Can you provide source.tif for us to try the same gdalwarp you did above?
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
