[Gdal-dev] Merging DEMs seamlessly
Tue Jun 6 12:32:09 EDT 2006
Chris Pennock wrote:
> All -
> Merging DEMs is a frequent topic, but the suggestion I
> often see is like:
> gdal_merge.py -o merged.tif dem1.dem dem2.dem
> I when this is done, even if the two DEMs being merged
> have the *same* corner points, I usually get a few
> points of empty space between the dems in the merged
> tif.
> Does anyone have any thoughts on why this would
> happen, or a possbile fix? Perhaps the culprit is that
> neither of of two dems has the set of height points
> closest to the line forming their interface. I
> thought, however, that for every column of height
> points, that one dem or the other would have each
> point on the column.
> Many thanks in advance for this very newbie question!
Chris,
Can you provide a couple of DEM files which demonstrate this problem?
And what version of gdal_merge.py you are using?  There were some adjustments
made to try and address edge-effects some months ago.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
