[Gdal-dev] VRT to turn multiple points into a polyline
Daniel Morissette dmorissette at mapgears.com
Wed Jun 7 16:44:18 EDT 2006
Let's say I have a flat database table with an X and a Y column, it is
easy to create a OGR-VRT data source to return the records as points.
Is there a way using the VRT driver to return a set of records with X,Y
columns as a single LineString instead of multiple points?
The reason why I'm asking is that I have an Oracle database with X, Y,
and TIMESTAMP columns, and I would like to use a SQL query in a VRT to
select multiple points over a period of time and return them as a track
(a LineString) instead of individual points for use in MapServer.
Does anyone know of a way to do that?
Daniel
Daniel Morissette
http://www.mapgears.com/
