[Gdal-dev] ogrinfo and oracle spatial
Daniel Goetz madprof at gmx.ch
Fri Jun 9 06:26:38 EDT 2006
Thank you Mateusz for your help.
Unfortunatelly the command: "ogrinfo OCI:gds_brwk2004_umn/umn at gds1prod" brought back the following (this tiem I used the ogrinfo integrated in ms4w:
FAILURE:
Unable to open datasource 'OCI:gds_brwk2004_umn/umn at gds1prod' with the following drivers.
-> ESRI Shapefile
->MapInfo File
->UK .NTF
->SDTS
->TIGER
->S57
->DGN
->VRT
->AVCBin
->REC
->Memory
->CSV
->GML
->ODBC
->PGeo
->PostgreSQL
->MySQL
Subsequent I watched out fo the supported formats by commanding: "ogrinfo --formats"
the result was:
Loaded OGR Format Drivers:
->"ESRI Shapefiel"
->"MapInfo File"
->"UK .NTF"
->"SDTS"
->"S57"
->"DGN"
->"VRT"
->"AVCBin"
->"REC"
->"Memory"
->"CSV"
->"GML"
->"ODBC"
->"PGeo"
->"PostgreSQL"
->"MySQL"
Can you please tell me whether the needed driver for oracle spatial is supported in my OGR. Can you tell me what I further sould do.
Thank you very much.
regards
Daniel Goetz
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
