[Gdal-dev] gdaltindex on numerous files
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Wed Jun 14 10:32:51 EDT 2006
Ivan,
Thanks for the info. This did the trick:
$ find $PWD -name "*.tif" -exec gdaltindex srtm-index3 {} \;
Thanks
..Tom
-----Original Message-----
Sent: Wed 14-Jun-06 10:26
To: Kralidis,Tom [Burlington]; gdal-dev at lists.maptools.org
Cc:
Subject: RE: [Gdal-dev] gdaltindex on numerous files
Tom,
UNIX handles wildcard different than Windows. It will expand it and then
rebuild your command line. That is way it could be to long.
You should make UNIX create one command for each file found using
something like:
$ find $PWD -name '*.tif' -exec gdaltindex ... \;
Good luck,
Ivan
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Kralidis,Tom
[Burlington]
Sent: 14 June 2006 10:08
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] gdaltindex on numerous files
I'm trying to create a MapServer tileindex via gdaltindex, where I would
like to store the absolute paths to each raster image in the output
tileindex.
Trying this gives me the following error:
$ gdaltindex srtm-index2 $PWD/*.tif
-bash: /usr/local/bin/gdaltindex: Argument list too long
Does gdaltindex take a filelist as an argument? Trying:
$ gdaltindex srtm-index2 < some_file
$ gdaltindex srtm-index2 some_file
...didn't work.
Any advice would be much appreciated.
Thanks
..Tom
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
