[Gdal-dev] Compile GDAL with VS2005 (BuildKit Source Code)
Zhonghai Wang zhonghaiw at gmail.com
Wed Jun 14 16:36:57 EDT 2006
Hi Howard,
thanks you so much for the important HINTS.
so you mean that I must compile all the needed libraries in the BuildKit
package myself with VS2005? Is this compilation guide still valid for the
whole compilation?
http://www.nabble.com/Windows-build-kit-for-MSVC-7.1-t1143108.html#a2997024>
http://www.nabble.com/Windows-build-kit-for-MSVC-7.1-t1143108.html#a2997024.<http://www.nabble.com/Windows-build-kit-for-MSVC-7.1-t1143108.html#a2997024>
so the steps may be:
1. compile the required libraries for GDAL (according to the component that
I need)
2. compile GDAL
3. compile the required libraries for MapServer
4. compile MapServer
and here is the last question^_^:
what does the command "nmake /f makefile.vc install" mean? for this command
which parameters in the nmake.opt file should be set correctly?
I really appreciate your help.
best regards
zhonghai
On 6/14/06, Howard Butler <hobu at iastate.edu> wrote:
> Zhonghai,
> Yes GDAL can be compiled with MSVC 6, MSVC 2003, and MSVC 2005 --
> from scratch  The buildkit on hobu.stat.iastate.edu is *specifically*
> for MSVC 2003.  This is because all of the "support" libraries have
> been compiled for you.  For example, in your pasted output, it is
> complaining about linkage errors with GEOS.  This is because GEOS was
> compiled with MSVC 2003, and the two C++ runtimes (MSVC 2003 (7.1)
> and MSVC 2005 (8.0)) are incompatible.  To successfully use the
> buildkit, you would have to recompile *every* library that
> MapServer/GDAL brings in with MSVC 2005.
> The buildkit is not of much use if you have to recompile everything
> for your compiler platform.  Maybe someday, when I get MSVC 2005, I
> will roll out a buildkit for that as well.  In the interim, you are
> probably best off by downloading everything you need as source and
> building it all up individually.  Alternatively, you could switch to
> MSVC 2003 and use the buildkit, or start with the buildkit and go in
> and recompile each and every support library that you plan to
> link/use with MapServer/GDAL and MSVC 2005.
> Howard
> At 03:04 PM 6/14/2006, Zhonghai Wang wrote:
> >hi there,
> >been pasted this message in MapServer mailing list, but I realized
> >that it may be better if I paste it here, since it's GDAL problem.
> >Sorry for the duplicated message.
> >I am trying to compile GDAL with VS2005, but there are  a lot of
> >error messages after the namake /f <http://makefile.vc>makefile.vc
> >command. Here is what I have done:
> >1.source code download: -- the MapServer BuildKit from Howard Butler
> ><http://hobu.stat.iastate.edu/mapserver/build_output/>
> >    and I have downloaded the latest package version
> > "mapserver-4.8.3-2-msvc71-buildk-kit.zip"
> >2.and I follow the compilation guide here:
> >    to compile MapServer, according to this doc, I should at first
> > compile the GDAL package, and then come to the MapServer package.
> > But when I am trying to compile the GDAL
> >    package under VS2005 command prompt with the command "nmake /f
> > <http://makefile.vc/>makefile.vc", there are some error messages
> > appears, the scenario is:
> >*C:\buildkit\gdal-1.3.2>nmake /f <http://makefile.vc/>makefile.vc clean
> >*and here come the error messages, I paste only the first one here,
> >because I think if I fix this problem, the other error may be fixed
> >at the same time:
> >*msvcprt.lib(MSVCP80.dll) : error LNK2005: "class
> >std::basic_string<char,struct s
> >*td::char_traits<char>,class std::allocator<char> > __cdecl
> >std::operator+<char,s
> >*truct std::char_traits<char>,class std::allocator<char> >(class
> >std::basic_strin
> >*g<char,struct std::char_traits<char>,class std::allocator<char> >
> >const &,char c
> >*onst *)"
> >(<http://www.nabble.com/user/SendEmail.jtp?type=post&post=4867349&i=0>
> >??$?HDU?$char_traits at ...*
> >*<http://www.nabble.com/user/SendEmail.jtp?type=post&post=4867349&i=1
> >already defined in geos
> >*.lib(WKTReader.obj)
> >I am really confused now, i am just wondering if GDAL can be
> >compiled with VS2005, or it can only be compiled with VC ++ 6?
> >thanks for any information.
> >zhonghai
> >_______________________________________________
> >Gdal-dev mailing list
> >Gdal-dev at lists.maptools.org
> >http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060614/0dacd151/attachment.html
