[Gdal-dev] Tool to convert shapefile from [-180, 180] to [0, 360] range
Daniel Morissette dmorissette at mapgears.com
Wed Jun 14 16:59:25 EDT 2006
OOpps.. the file I just sent contained a typo in the bNeedToShift test.
Works fine for points still since minx == maxx, but would not have
worked too well for some polygons or linestrings.
Here is what it should have been:
        bNeedToShift = ((oEnv.MinX+oEnv.MaxX)/2.0<0.0) ? TRUE : FALSE;
Daniel
Daniel Morissette wrote:
> Mateusz Loskot wrote:
>> I created small utility on basis of ogr2ogr according your needs, just
>> for fun and practice :-)
>> I attached it as a 180to360.cpp file, so it's a C++ application.
>> I hope this attachement will not be cutted off by the gdal-dev mailer.
>> It works only with shapefiles.
>> This utility just adds 180 to every x coordinate.
>> So, it works well only if input coordinates are in range frm -180 to
>> 180, but it does not check it.
> Hi Mateusz,
> Thanks for the little program, that's what I was thinking of doing too.
> In case anyone is interested, I have attached a new version that I
> modified it a little bit to:
> 1- Shift by +360 instead of +180. i.e. -50 degrees = +310 degrees
> 2- Shift coordinates only if the centroid of the source feature is in
> the [-180,0] range
> One last thing to do would be support for geometries other than points
> (at least linestrings and polygons).
> Daniel
> // Converts longtitude format from -180;180 to 0;360 degrees
> // This program was created on basis of ogr2ogr
> #include "ogrsf_frmts.h"
> #include "ogr_p.h"
> #include "cpl_conv.h"
> #include "cpl_string.h"
> #include "ogr_api.h"
> static void Usage();
> static int TranslateLayer( OGRDataSource *poSrcDS,
>                            OGRLayer * poSrcLayer,
>                            OGRDataSource *poDstDS,
>                            char ** papszLSCO,
>                            const char *pszNewLayerName,
>                            int bTransform,
>                            OGRSpatialReference *poOutputSRS,
>                            OGRSpatialReference *poSourceSRS,
>                            char **papszSelFields,
>                            int bAppend, int eGType,
>                            int bOverwrite );
> static int bSkipFailures = FALSE;
> static int nGroupTransactions = 200;
> static int bPreserveFID = FALSE;
> static int nFIDToFetch = OGRNullFID;
> /*                                main()                                */
> int main( int nArgc, char ** papszArgv )
>     const char  *pszFormat = "ESRI Shapefile";
>     const char  *pszDataSource = NULL;
>     const char  *pszDestDataSource = NULL;
>     char        **papszLayers = NULL;
>     char        **papszDSCO = NULL, **papszLCO = NULL;
>     int         bTransform = FALSE;
>     int         bAppend = FALSE, bUpdate = FALSE, bOverwrite = FALSE;
>     const char  *pszOutputSRSDef = NULL;
>     const char  *pszSourceSRSDef = NULL;
>     OGRSpatialReference *poOutputSRS = NULL;
>     OGRSpatialReference *poSourceSRS = NULL;
>     const char  *pszNewLayerName = NULL;
>     const char  *pszWHERE = NULL;
>     OGRGeometry *poSpatialFilter = NULL;
>     const char  *pszSelect;
>     char        **papszSelFields = NULL;
>     const char  *pszSQLStatement = NULL;
>     int         eGType = -2;
> /*      Register format(s).                                             */
>     OGRRegisterAll();
> /*      Processing command line arguments.                              */
>     nArgc = OGRGeneralCmdLineProcessor( nArgc, &papszArgv, 0 );
>     if( nArgc != 3 )
>         Usage();
>         exit( -nArgc );
>    pszDataSource = papszArgv[1];
>    pszDestDataSource = papszArgv[2];
> /*      Open data source.                                               */
>     OGRDataSource       *poDS;
>     poDS = OGRSFDriverRegistrar::Open( pszDataSource, FALSE );
> /*      Report failure                                                  */
>     if( poDS == NULL )
>         OGRSFDriverRegistrar    *poR = OGRSFDriverRegistrar::GetRegistrar();
>         printf( "FAILURE:\n"
>                 "Unable to open datasource `%s' with the following drivers.\n",
>                 pszDataSource );
>         exit( 1 );
> /*      Try opening the output datasource as an existing, writable      */
>     OGRDataSource       *poODS;
>     OGRSFDriver          *poDriver = NULL;
>     int                  iDriver;
>     poDriver = OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName(pszFormat);
>     if( poDriver == NULL )
>         printf( "Unable to use driver `%s'.\n", pszFormat );
>         exit( 1 );
> /*      Create the output data source.                                  */
>     poODS = poDriver->CreateDataSource( pszDestDataSource, papszDSCO );
>     if( poODS == NULL )
>         printf( "%s driver failed to create %s\n",
>                 pszFormat, pszDestDataSource );
>         exit( 1 );
> /*      Process each data source layer.                                 */
>     for( int iLayer = 0;
>          pszSQLStatement == NULL && iLayer < poDS->GetLayerCount();
>          iLayer++ )
>         OGRLayer        *poLayer = poDS->GetLayer(iLayer);
>         if( poLayer == NULL )
>             printf( "FAILURE: Couldn't fetch advertised layer %d!\n",
>                     iLayer );
>             exit( 1 );
>         if( CSLCount(papszLayers) == 0
>             || CSLFindString( papszLayers,
>                               poLayer->GetLayerDefn()->GetName() ) != -1 )
>             if( !TranslateLayer( poDS, poLayer, poODS, papszLCO,
>                                  pszNewLayerName, bTransform, poOutputSRS,
>                                  poSourceSRS, papszSelFields, bAppend, eGType,
>                                  bOverwrite )
>                 && !bSkipFailures )
>                 CPLError( CE_Failure, CPLE_AppDefined,
>                           "Terminating translation prematurely after failed\n"
>                           "translation of layer %s\n",
>                           poLayer->GetLayerDefn()->GetName() );
>                 exit( 1 );
> /*      Close down.                                                     */
>     delete poODS;
>     delete poDS;
>     CSLDestroy(papszSelFields);
>     CSLDestroy( papszArgv );
>     CSLDestroy( papszLayers );
>     OGRCleanupAll();
> #ifdef DBMALLOC
>     malloc_dump(1);
> #endif
>     return 0;
> /*                               Usage()                                */
> static void Usage()
>     printf( "Usage: ogr2ogr <input dst> <output dst>\n"
>     exit( 1 );
> /*                           TranslateLayer()                           */
>                            char **papszLCO,
>                            int bTransform,
>                            int bAppend, int eGType, int bOverwrite )
>     OGRLayer    *poDstLayer;
>     OGRFeatureDefn *poFDefn;
>     OGRErr      eErr;
>     int         bForceToPolygon = FALSE;
>     int         bForceToMultiPolygon = FALSE;
>     if( pszNewLayerName == NULL )
>         pszNewLayerName = poSrcLayer->GetLayerDefn()->GetName();
> /*      Get other info.                                                 */
>     poFDefn = poSrcLayer->GetLayerDefn();
>     if( poOutputSRS == NULL )
>         poOutputSRS = poSrcLayer->GetSpatialRef();
> /*      Find the layer.                                                 */
>     int iLayer = -1;
>     poDstLayer = NULL;
>     for( iLayer = 0; iLayer < poDstDS->GetLayerCount(); iLayer++ )
>         OGRLayer        *poLayer = poDstDS->GetLayer(iLayer);
>         if( poLayer != NULL
>             && EQUAL(poLayer->GetLayerDefn()->GetName(),pszNewLayerName) )
>             poDstLayer = poLayer;
>             break;
> /*      If the layer does not exist, then create it.                    */
>     if( poDstLayer == NULL )
>         if( eGType == -2 )
>             eGType = poFDefn->GetGeomType();
>         CPLAssert( poDstDS->TestCapability( ODsCCreateLayer ) );
>         CPLErrorReset();
>         poDstLayer = poDstDS->CreateLayer( pszNewLayerName, poOutputSRS,
>                                            (OGRwkbGeometryType) eGType,
>                                            papszLCO );
>             return FALSE;
>         bAppend = FALSE;
> /*      Add fields.  Default to copy all field.                         */
> /*      If only a subset of all fields requested, then output only      */
> /*      the selected fields, and in the order that they were            */
> /*      selected.                                                       */
>     int         iField;
>     for( iField = 0; iField < poFDefn->GetFieldCount(); iField++ )
>         poDstLayer->CreateField( poFDefn->GetFieldDefn(iField) );
> /*      Transfer features.                                              */
>     OGRFeature  *poFeature;
>     poSrcLayer->ResetReading();
>     while( TRUE )
>         OGRFeature      *poDstFeature = NULL;
>         poFeature = poSrcLayer->GetNextFeature();
>         if( poFeature == NULL )
>             break;
>         CPLErrorReset();
>         poDstFeature = OGRFeature::CreateFeature( poDstLayer->GetLayerDefn() );
>         if( poDstFeature->SetFrom( poFeature, TRUE ) != OGRERR_NONE )
>                       "Unable to translate feature %d from layer %s.\n",
>                       poFeature->GetFID(), poFDefn->GetName() );
>             OGRFeature::DestroyFeature( poFeature );
>             OGRFeature::DestroyFeature( poDstFeature );
>             return FALSE;
>         if( bPreserveFID )
>             poDstFeature->SetFID( poFeature->GetFID() );
>         OGRGeometry* poGeom = poDstFeature->GetGeometryRef();
>         // We will shift coordinates by +360 only if object centroid is in the
>         // [-180, 0] range, otherwise we leave the coordinates untouched
>         GBool bNeedToShift = FALSE;
>         if (poGeom)
>             OGREnvelope oEnv;
>             poGeom->getEnvelope(&oEnv);
>             bNeedToShift = ((oEnv.MinX+oEnv.MinX)/2<0.0) ? TRUE : FALSE;
>         if( bNeedToShift )
>             OGRwkbGeometryType wkbType = poGeom->getGeometryType();
>             if ( wkbPoint == wkbType )
>                 OGRPoint* poPoint = static_cast<OGRPoint*>(poGeom);
>                 double x = poPoint->getX();
>                 if (bNeedToShift)
>                 poPoint->setX(x + 360);
>         CPLErrorReset();
>         if( poDstLayer->CreateFeature( poDstFeature ) != OGRERR_NONE
>             && !bSkipFailures )
>             return FALSE;
>     return TRUE;
Daniel Morissette
http://www.mapgears.com/
