[Gdal-dev] How to split multi-layer geotiff images
Clay, Bruce bclay at ball.com
Wed Jun 14 17:49:59 EDT 2006
 I have had problems getting this message posted.  - the send keeps
timing out.  I apologize if multiples finally get sent out
Can GDAL be used to open multi-layer Geotiff raster files?
Not multi-band but more than one image in the same file. I was given
some Geotiff images that Microsoft Office Imaging tool shows 2 distinct
images in a single tiff file.
IDL was used to create the file using an APPEND function.
ArcMap does not seem to be able to find the second images so I would
like to extract the image using GDAL but I don't see any info in the
documentation.
Tiffsplit in the FW tool set will split the file into 2 images but it
kicks up some error messages
C:\GisTeam\Data\APC_tree\SL\data\UnitedStates\31251>H:\SupportLibraries\
FWTools1.0.0b2\bin\tiffsplit 20060122_001_1200z_n34.00_w84.00_SFP.tif
TIFFReadDirectory: Warning, 20060122_001_1200z_n34.00_w84.00_SFP.tif:
unknown field with tag 33550 (0x830e) encountered.
unknown field with tag 33922 (0x8482) encountered.
unknown field with tag 34735 (0x87af) encountered.
The resulting images have no spatial reference information in them.
Bruce
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060614/0c1199c8/attachment.html
