[Gdal-dev] Problem with GDALWARP - very fast to solve
Jan B. digar at gmx.net
Thu Jun 15 02:17:53 EDT 2006
I have again a small problem with the gdalwarp command line tool.
I try to convert the file, which you can find under :
www.esw.rwth-aachen.de/n56e010.bil
with the following command into the UTM System:
gdalwarp -t_srs "+proj=utm +zone=11 +datum=WGS84" n56e010.bil test.tif
But it always says that too many points failed to transform. What would be
the correct command ???
Greetings (and hopefully I have specified the problem this time enought)
Jan Beiten
