[Gdal-dev] Tool to convert shapefile from [-180, 180] to [0, 360] range
Fri Jun 16 15:26:07 EDT 2006
Daniel Morissette wrote:
> Is anyone aware of a tool or script that would convert the longitude of
> coordinates in a shapefile from [-180,180] to [0,360]? The tool could be
> based on OGR or any other open source package.
> Just checking before writing something from scratch and reinventing the
> wheel.
Daniel,
I imagine you have what you need working now, and I see there was an
extensive thread on this issue.  I just wanted to add that in recent
works I've done some work on the OGRCoordinateTransformation object
related to supporting a "wrapping center" for geographic coordinate
systems.
It is now possible to define a wrapping center longitude, and the
OGRCoordinateTransformation object will take care of forcing longitudes
into the range center-180 to center+180.  This can be accomplished using
the CENTER_LONG configuration option like this:
   gdalwarp --config CENTER_LONG 180 openev/utm.tif ll.tif -t_srs WGS84
In the above case, the output lat/long file will use the range 0 to 360
instead of the default -180 to 180.
I also have an extension to WKT for setting this.  I believe you add
an entry like EXTENSION["CENTER_LONG",180] as a child of the GEOGCS node.
I would have mentioned this whole issue here sooner, except that I just
know that Martin Daly will now rightly jump all over me for corrupting
the standard WKT format.  I must say, I now regret not having advocated
on behalf of a vendor specific extension mechanism in the past. :-)
The gdalwarp utility now has some built-in smarts to apply a CENTER_LONG
to the source coordinate system center in the middle of the dataset.  The
original problem that motivated me to do something had to do with reprojection
away from lat/long and the projected coordinates for sampling not reprojecting
back onto the source dataset in the proper range.
I haven't written up an RFC on all this as I consider it quite experimental
though I must confess I have committed it in CVS.
In your case, I think it should be possible to run ogr2ogr like:
   ogr2ogr out.shp in.shp --config CENTER_LONG 180 -t_srs WGS84 -t_srs WGS84
though I haven't tried it to see if there are issues.  This certainly won't
take care of splitting a geometry that crosses the meridian as ought to be
done when transforming.  For points this won't matter, but it will for
line or polygon files.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
