[Gdal-dev] OGR can't handle Null values in a Date field
Fri Jun 16 18:35:44 EDT 2006
Aaron Koning wrote:
> I have just started using a newer version of OGR that includes Date
> support. (Context: I am importing shapefiles into PostgreSQL using
> OGR/PHP). Unfortunately, when I there is a Null value in a Date field of
> the input shapefile OGR bails (after successfully inserting non-null
> values). From what I can see, it attempts to do an insert with a
> '00/00/00 00:00:00' value and PostgreSQL states I may need another Date
> type for this value.
> Is there anyway of getting OGR to output Null values into a Date field
> when there is a Null value present in the input Date field?
> Alternatively, the previous versions of OGR simply converted Date fields
> to strings. Is there a way to revive this action (when I set the output
> field type to string instead of bool, it doesn't work).
Aaron,
Date fields are intended to support nulls.  Could you provide me
with a shapefile with some null dates I could test with?  I think there
is just a bug at some point in the code with null propogation in date fields.
Best regards,--
and watch the world go round - Rush    | President OSGF, http://osgeo.org
