[Gdal-dev] nodata -> alpha in TIFF output?
William Kyngesburye woklist at kyngchaos.com
Sat Jun 17 13:30:49 EDT 2006
I want to convert an RGB image group from GRASS, which has null/
nodata cells to an RGB TIFF with an alpha channel for the nodata
cells.  I see that the TIFF format has an ALPHA=YES creation option,
but that assumes that I have an extra band in the input for the
nodata cells.  Is there a direct method/option, or do I need to add a
nodata band to the GRASS image group?
The -a_nodata option doesn't seem to work for multiband images (ie -
a_nodata 0,0,0 or just 0).  If it did I could take the first
conversion where the nodata values become black and convert it again
with the nodata option.  Assuming I don't have any pure black in the
actual image.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do
if you ARE a maniacally depressed robot?  No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
