[Gdal-dev] using OGRLayer::SetSpatialFilter to access polygons in .shp files
Sat Jun 17 23:06:12 EDT 2006
Amanda Tucker wrote:
> Hello,
> My goal is to input a point (lat/long) and to get all polygons that
> contain this point.  I am using SetSpatialFilter() to filter on the
> specified point.  I am being returned correct features (polygons), but
> often, I am getting extra polygons.  I can see through GUI tools that
> some polygons/multipolygons are being returned that do not contain the
> point.  The doc for SetSpatialFilter() states ‘currently this test may
> be inaccurately implemented’.  Are there known cases that this method is
> inaccurate?  And is this one of those cases?  Is there another way to
> get the results I desire?  I also tried using within()/contain() after
> these polygons were returned, but that did not work because I am not
> building with GEOS.  Is there any way I can get the correct results
> without building with GEOS?  And if not, where do I find the GEOS
> binaries/source code to build with OGR?  And will these methods in GEOS
> even solve my problem?
Amanda,
I believe the test is always passed on comparing the feature geometries
bounding rectangle to the spatial filter's bounding rectangle unless
GEOS support is built in, in which case I think a real intersection test
is done.
I believe FWTools is always built with GEOS if you want to use that for
a quick trial.  http://fwtools.maptools.org/
GEOS can be found at http://geos.refractions.net/
I see there is a PointOnSurface() method on the OGRPolygon that is not
yet implemented.  I likely ought to wire that to something when GEOS is
available.  In fact, point in polygon is not a very hard test for me to
do with using GEOS.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
