[Gdal-dev] IPCC raster format
Tim Sutton tim at linfiniti.com
Sun Jun 18 19:26:39 EDT 2006
Hi
I wrote a tool in c++ once to read this and if I recall correctly
spit out arc/info ascii grid files. Its been a while since I looked
at it so Ill need to dig it up and recheck exactly what it did. Pete
can you remember if this is in the climate data processing wizard? I
have no network access as I write this so I will only be able to
confirm for you tomorrow what I actually have. Ivan if you still
have not found a suitable solution and Ill dig out what I have.
Regards
Tim
On 16/06/2006, at 12:08, Ivan Lucena wrote:
> Hi there,
> I would rather been watching the World Cup, but I have to get this
> data in a usable format and there is no better place to get it than
> from GDAL’s experts.
> The “Intergovernmental Panel on Climate Change” (IPCC) offers data
> on the web in a format described by this Fortran source code: (The
> file extension is just a generic “.dat”)
> http://ipcc-ddc.cru.uea.ac.uk/obs/observed_fileformat.html
> > more cpre0130.dat
>     grd_sz      xmin      ymin      xmax      ymax    n_cols
> n_rows  n_months
>       0.50      0.25    -89.75    359.75     89.75       720
> 360        12
> -9999-9999-9999-9999-9999-9999-9999-9999-9999   52   88  103   91
> 65   45   27   32 …
> -9999-9999-9999-9999-9999   11   20   22   25   27   26   27   28
> 31   29   28   30 …
> It’s not hard to analyze the pattern on the data or the code, so I
> figured that:
> - It’s an ASCII format;
> - There are two lines of reader (easy to read)
> - Each cell is 5 characters wide;
> - The no-data is “-9999”;
> - There is no separator between cells (what makes my task difficult);
> - It’s a multi-band raster dataset with 12 bands; (720x360x12 cells)
> - I am not sure if positive values can go beyond 9999 (that reminds
> me COBOL)
> I am heading in the direction of writing a Python+GDAL script to do
> the task, but I am stuck in how to separate the cells. The Fortran
> code is doing it in just one command as you can see in the code. I
> am thing that maybe by using the NumPY stuff embedded in GDAL I
> could do the same.
> Any Idea? Any experience with this data format?
> Thanks in advance,
> Ivan
> This is a Python command line interaction with the data:
> >>> import gdal
> >>> f = open('C:/Data/IPCC/cpre0130.dat', 'r');
> >>> f.readline()
> '    grd_sz      xmin      ymin      xmax      ymax    n_cols
> n_rows  n_months\n'
> >>> f.readline()
> '      0.50      0.25    -89.75    359.75     89.75       720
> 360        12\n'
> >>> f.readline()
> '-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-999
> 9-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-9999-999
> program rd_ascii
> ! f90 program to read in an integer ascii grid with
> ! variable dimensions into a global grid (720x360x12)
>   parameter :: n_cols=720
>   parameter :: n_rows=360
>   integer, dimension (n_cols,n_rows,12) :: grid
>   character(len=72) :: infl
>   character(len=20) :: fmt
>   call getarg(1,infl)
>   if(infl.eq.' ')then
>     write(*,*) 'Enter ascii grid file name'
>     read(*,'(a72)')infl
>   end if
>   open(1,file=infl,status='old')
>   read(1,*)
>   read(1,*)xmin,ymin,xmax,ymax,ncols,nrows,nmonths,missing
>   grid=missing
>   fmt='( i5)'
>   write(fmt(2:4),'(i3)')n_cols
>   do im=1,nmonths
>     do lat=1,n_rows
>       read(1,fmt)(grid(lon,lat,im),lon=1,n_cols)
>     enddo
>   enddo
> end program rd_ascii
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Tim Sutton
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060618/59831d72/attachment.html
