[Gdal-dev] ESRI ArcSDE OGR driver
Wed Jun 21 11:43:08 EDT 2006
cemehehko wrote:
> Hello gdal-dev,
> What about OGR driver to read/write from/into ArcGis SDE with
> ArcSDE developer API? My SDE instance is over Oracle but I think that
> this is not the best idea to use OGR/OCI driver. I not found table
> ALL_SDO_GEOM_METADATA. I use Oracle Spatial to store my geometries in
> SDE setup files for speed and convineince .
> But ArcSDE can store no only over Oracle DBMS (M$ SQL, IBM, etc).
> ArcSDE can also store geometries in BLOBs with WKB inside. There why I
> want to use "native" ArcSDE API to process SDE layers.
Cemehehko,
GDAL/OGR 1.3.2 includes a read-only SDE driver using the SDE C API.  So
to build this driver you need to have a copy of the SDE C API developer
kit from ESRI.  This driver could be extended to read/write support, but
that was not a priority for the client who drove this work (Delorme), so
it wasn't pursued.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
