[Gdal-dev] Re: problems with "GDAL + Java SWIG" set up on Windows XP
Daniele Romagnoli dany.geotools at gmail.com
Wed Jun 21 13:21:45 EDT 2006
Ok... I have solved the last error but a new error occurs:
/bin/sh.exe /cygdrive/c/gdal2/libtool --mode=compile g++ -fPIC -Wall  -O2
-I/cygdrive/c/gdal2/port -I/cygdrive/c/gdal2/gcore -I/cygdrive/c/gdal2/alg
-I/cygdrive/c/gdal2/ogr -I/cygdrive/c/gdal2/ogr/ogrsf_frmts
-I/usr/j2sdk1.4.2_08/include -I/usr/j2sdk1.4.2_08/include/win32 -c
osr_wrap.cpp
 g++ -fPIC -Wall -O2 -I/cygdrive/c/gdal2/port -I/cygdrive/c/gdal2/gcore
-I/cygdrive/c/gdal2/alg -I/cygdrive/c/gdal2/ogr
-I/cygdrive/c/gdal2/ogr/ogrsf_frmts -I/usr/j2sdk1.4.2_08/include
-I/usr/j2sdk1.4.2_08/include/win32 -c osr_wrap.cpp  -DPIC -o
.libs/osr_wrap.o
osr_wrap.cpp:1: warning: -fPIC ignored for target (all code is position
independent)
-I/usr/j2sdk1.4.2_08/include/win32 -c osr_wrap.cpp -o osr_wrap.o >/dev/null
2>&1
/bin/sh.exe /cygdrive/c/gdal2/libtool --mode=link       g++ -shared
/cygdrive/c/gdal2/libgdal.la osr_wrap.o -o libosrjni.so
g++ -shared osr_wrap.o -o libosrjni.so.exe
/cygdrive/c/gdal2/.libs/libgdal.a /usr/lib/libjasper.dll.a -L/usr/X11R6/lib
/usr/lib/libtiff.dll.a /usr/lib/libjpeg.dll.a -lpng -lz
cp ./.libs/*.so ./
cp: cannot stat `./.libs/*.so': No such file or directory
make: *** [build] Error 1
However, I see that in the directory there are 4 files *.so.exe
Maybe can I rename them from *.so.exe to *.so and then move them to the
/.libs folder?
Regards
On 6/21/06, Daniele Romagnoli <dany.geotools at gmail.com> wrote:
> Hi guys,
> I'm trying to set up under Windows XP all the items needed to use GDAL
> with JAVA.
> Norman Barker has already given a great help to me but I have some
> problems.
> Using the procedure found at
> http://article.gmane.org/gmane.comp.gis.gdal.devel/6109/match=gdal+visual+c+++expressplus some other tips, an error occurs:
> C:\gdal\frmts>cd gtiff   && nmake /NOLOGO /f makefile.vc   && cd ..
>         cl /nologo /MD /EHsc /Zi /Fd..\..\gdal.pdb -I..\..\port
> -I..\..\ogr -I..
> \..\gcore  -I..\..\alg -Ilibtiff -Ilibgeotiff /c tifvsi.cpp
> tifvsi.cpp
> C:\Programmi\Microsoft Visual Studio 8\VC\INCLUDE\swprintf.inl(41) : error
> C2664
> : '_vswprintf_c_l' : cannot convert parameter 4 from 'void *' to
> '_locale_t'
>         Conversion from 'void*' to pointer to non-'void' requires an
> explicit ca
> st
> C:\Programmi\Microsoft Visual Studio 8\VC\INCLUDE\swprintf.inl(51) : error
> C2664
> '_locale_t'
> explicit ca
> st
> NMAKE : fatal error U1077: '"C:\Programmi\Microsoft Visual Studio
> 8\VC\BIN\cl.EX
> E"' : return code '0x2'
> Stop.
> So, I have tried the "cygwin" way to build GDAL and it seems working:
> ./configure
> make
> make install
> However, when I follow the steps suggested by Ben Collins at
> http://lists.maptools.org/pipermail/gdal-dev/2006-February/007867.html,
> this error occurs:
> -I/cygdrive/c/gdal2/ogr/ogrsf_frmts -I/usr/java/j2sdk1.4.2_08/include
> -I/usr/java/j2sdk1.4.2_08/include/win32 -c osr_wrap.cpp
> -I/usr/java/j2sdk1.4.2_08/include/win32 -c osr_wrap.cpp  -DPIC -o
> .libs/osr_wrap.o
> independent)
> osr_wrap.cpp: In function `__jobjectArray*
> Java_org_gdal_osr_osrJNI_GetProjectionMethods(JNIEnv*, __jclass*)':
> osr_wrap.cpp:2233: error: invalid conversion from `__jarray*' to
> `__jobjectArray*'
> Java_org_gdal_osr_osrJNI_GetProjectionMethodParameterList(JNIEnv*,
> __jclass*, __jstring*, __jobjectArray*)':
> osr_wrap.cpp:2285: error: invalid conversion from `__jarray*' to
> `__jobjectArray*'
> make: *** [osr_wrap.o] Error 1
> Maybe I blundered during some step.
> Anyone can help me?
> Regards,
> Daniele
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060621/7f611838/attachment.html
