[Gdal-dev] Re: Bugs in the bindings
Charlie Savage cfis at interserv.com
Mon Jun 26 16:44:54 EDT 2006
> My problem is that the croak (even swig_croak) is probably a Perl-only
> solution, but I'll look into it more and post it as a bug -- that's an
> example of a general bindings bug or "undesirable feature".
Ari - could you use SWIG_exception (see
http://www.swig.org/Doc1.3/SWIGDocumentation.html#Library_stl_exceptions).
  That's generic across SWIG bindings.  There is also a slightly
different version (whose name I can't remember, something like
SWIG_Error) in the unified type library.  It handles raising the
exception a little differently, so if SWIG_exception doesn't work then
maybe the other one will.
> BTW, my plans for the classes in Geo::GDAL namespace have escalated a
> bit (after reading Sean's and Charlie's posts on geos-devel). For
> example I intend to introduce Geo::GDAL::Point etc. classes and leave
> the Geometry class, whihc swig bindings provide, as a virtual class (not
> to instantiated by users).
I've attached what I've done so far on Geos for you to take a look at.
Basically, create the "fake" classes just like Gdal already does.  Then
take a look at the return typemap in the enclosed file - seems to work fine.
While on the subject - 2 other things:
1.  Can we remove all the language specifiers in the typemaps, which are
now deprecated by SWIG (you get lots of warning when running SWIG on the
gdal bindings now).
2.  Feedback on the -fpic command line option I mentioned in  my last
email.  Its needed on SELinux enabled systems.
Thanks,
Charlie
%module geos
%include "attribute.i"
%include "exception.i"
%include "std_string.i"
%include "std_vector.i"
%include "std_except.i"
%include "factory.i"
typedef struct GeosCoordinateSequence_t *GeosCoordinateSequence;
typedef struct GeosGeometry_t *GeosGeometry;
typedef struct GeosPoint_t *GeosPoint;
typedef struct GeosLineString_t *GeosLineString;
typedef struct GeosLinearRing_t *GeosLinearRing;
typedef struct GeosPolygon_t *GeosPolygon;
typedef struct GeosGeometryCollection_t *GeosGeometryCollection;
typedef struct GeosMultiPoint_t *GeosMultiPoint;
typedef struct GeosMultiLineString_t *GeosMultiLineString;
typedef struct GeosMultiLinearRing_t *GeosMultiLinearRing;
typedef struct GeosMultiPolygon_t *GeosMultiPolygon;
// Constants from geos_c.h  sinc
#define GEOS_VERSION_MAJOR 3
#define GEOS_VERSION_MINOR 0
#define GEOS_VERSION_PATCH 0rc1
#define GEOS_VERSION "3.0.0rc1"
#define GEOS_JTS_PORT "1.7.1"
#define GEOS_CAPI_VERSION_MAJOR 1
#define GEOS_CAPI_VERSION_MINOR 1
#define GEOS_CAPI_VERSION_PATCH 1
#define GEOS_CAPI_FIRST_INTERFACE GEOS_CAPI_VERSION_MAJOR
#define GEOS_CAPI_LAST_INTERFACE (GEOS_CAPI_VERSION_MAJOR+GEOS_CAPI_VERSION_MINOR)
#define GEOS_CAPI_VERSION "3.0.0rc1-CAPI-1.1.1"
/* Supported geometry types */
    enum GEOSGeomTypes {
	GEOS_POINT,
	GEOS_LINESTRING,
	GEOS_LINEARRING,
	GEOS_POLYGON,
	GEOS_MULTIPOINT,
	GEOS_MULTILINESTRING,
	GEOS_MULTIPOLYGON,
	GEOS_GEOMETRYCOLLECTION
#include "geos_c.h"
//#include <sstream>
/* ==============  Language Specific Files ============ */
/* Import language specific SWIG files.  This allows each language
   to define its own renames as well as any special functionality
   such as language specific iterators for collections. Note
   that %include allows the included files to generate interface
   wrapper code while %import does not.  Thus use %include since
   this is an important feature (for example, Ruby needs it to #undef
   the select macro) */
#ifdef SWIGPYTHON
//	%include ../python/python.i
#endif
#ifdef SWIGRUBY
//	%include ../ruby/ruby.i
#endif
// ===  CoordinateSequence ===
%rename (CoordinateSequence) GeosCoordinateSequence;
class GeosCoordinateSequence
public:
%extend
    GeosCoordinateSequence(size_t size, size_t dims)
        return (GeosCoordinateSequence*) GEOSCoordSeq_create(size, dims);
    GeosCoordinateSequence(const GeosCoordinateSequence& other)
        GEOSCoordSeq coords = (GEOSCoordSeq) other;
        return (GeosCoordinateSequence*) GEOSCoordSeq_clone(coords);
    ~GeosCoordinateSequence()
        GEOSCoordSeq coords = (GEOSCoordSeq) self;
        return GEOSCoordSeq_destroy(coords);
    int setX(size_t idx, double val)
        return GEOSCoordSeq_setX(coords, idx, val);
    int setY(size_t idx, double val)
        return GEOSCoordSeq_setY(coords, idx, val);
    int setZ(size_t idx, double val)
        return GEOSCoordSeq_setZ(coords, idx, val);
    int setOrdinate(size_t idx, size_t dim, double val)
        return GEOSCoordSeq_setOrdinate(coords, idx, dim, val);
    double getX(size_t idx)
        double result;
        GEOSCoordSeq_getX(coords, idx, &result);
        return result;
    double getY(size_t idx)
        double result;
        GEOSCoordSeq_getY(coords, idx, &result);
        return result;
    double getZ(size_t idx)
        double result;
        GEOSCoordSeq_getZ(coords, idx, &result);
        return result;
    double getOrdinate(size_t idx, size_t dim)
        double result;
        GEOSCoordSeq_getOrdinate(coords, idx, dim, &result);
        return result;
    int getSize()
        size_t result;
        GEOSCoordSeq_getSize(coords, &result);
        return result;
    int getDimensions()
        size_t result;
        GEOSCoordSeq_getDimensions(coords, &result);
        return result;
// ===  Geometry ===
%typemap(out) GeosGeometry
    /* TestMe*/
    GeosGeometry geom = result;
    GEOSGeomTypes geomId = (GEOSGeomTypes)GEOSGeomTypeId((GEOSGeom) geom);
    switch (geomId)
    case GEOS_POINT:
        $result = SWIG_NewPointerObj(SWIG_as_voidptr(result), $descriptor(GeosPoint), 0 | $owner);
        break;
	case GEOS_LINESTRING:
        $result = SWIG_NewPointerObj(SWIG_as_voidptr(result), $descriptor(GeosLineString), 0 | $owner);
        break;
	case GEOS_LINEARRING:
        $result = SWIG_NewPointerObj(SWIG_as_voidptr(result), $descriptor(GeosLinearRing), 0 | $owner);
        break;
/*	case GEOS_POLYGON:
        break;
	case GEOS_MULTIPOINT:
        break;
	case GEOS_MULTILINESTRING:
        break;
	case GEOS_MULTIPOLYGON:
        break;
	case GEOS_GEOMETRYCOLLECTION:
        break;*/
/*    extern GEOSGeom GEOS_DLL GEOSPolygonize(const GEOSGeom geoms[],
	size_t ngeoms);
    GeosGeometry *Polygonize(size_t ngeoms)
        const GEOSGeom g1 = (GEOSGeom) self;
        return (GeosGeometry*) GEOSPolygonize(g1, ngeoms);
%rename(Geometry) GeosGeometry;
class GeosGeometry
private:
    GeosGeometry();
public:
%extend
    ~GeosGeometry()
        GEOSGeom geom = (GEOSGeom) self;
        GEOSGeom_destroy(geom);
    char *geomType()
        return GEOSGeomType(geom);
    int typeId()
        return GEOSGeomTypeId(geom);
    int getSRID()
        return GEOSGetSRID(geom);
    void setSRID(int SRID)
        return GEOSSetSRID(geom, SRID);
    size_t getDimensions()
        return GEOSGeom_getDimensions(geom);
    GeosGeometry *GEOSEnvelope()
        return (GeosGeometry*) GEOSEnvelope(g1);
    GeosGeometry *ConvexHull()
        return (GeosGeometry*) GEOSConvexHull(g1);
    GeosGeometry *Boundary()
        return (GeosGeometry*) GEOSBoundary(g1);
    GeosGeometry *PointOnSurface()
        return (GeosGeometry*) GEOSPointOnSurface(g1);
    GeosGeometry *LineMerge()
        return (GeosGeometry*) GEOSLineMerge(g1);
    GeosGeometry *GetCentroid()
        return (GeosGeometry*) GEOSGetCentroid(g1);
    GeosGeometry *Intersection(GeosGeometry *other)
        const GEOSGeom g2 = (GEOSGeom) other;
        return (GeosGeometry*) GEOSIntersection(g1, g2);
    GeosGeometry *Difference(GeosGeometry *other)
        return (GeosGeometry*) GEOSDifference(g1, g2);
    GeosGeometry *SymDifference(GeosGeometry *other)
        return (GeosGeometry*) GEOSSymDifference(g1, g2);
    GeosGeometry *Union(GeosGeometry *other)
        return (GeosGeometry*) GEOSUnion(g1, g2);
    GeosGeometry *Relate(GeosGeometry *other)
        return (GeosGeometry*) GEOSRelate(g1, g2);
    GeosGeometry *Buffer(double width, int quadsegs)
        return (GeosGeometry*) GEOSBuffer(g1, width, quadsegs);
    GeosGeometry *Simplify(double tolerance)
        return (GeosGeometry*) GEOSSimplify(g1, tolerance);
    GeosGeometry *TopologyPreserveSimplify(double tolerance)
        return (GeosGeometry*) GEOSTopologyPreserveSimplify(g1, tolerance);
%rename(Point) GeosPoint;
class GeosPoint: public GeosGeometry
private:
    GeosPoint();
    GeosPoint(const GeosPoint&);
public:
%extend
    ~GeosPoint()
%rename(LineString) GeosLineString;
class GeosLineString: public GeosGeometry
private:
    GeosLineString();
public:
%extend
    ~GeosLineString()
%rename(LinearRing) GeosLinearRing;
class GeosLinearRing: public GeosGeometry
private:
    GeosLinearRing();
public:
%extend
    ~GeosLinearRing()
%rename(Polygon) GeosPolygon;
class GeosPolygon: public GeosGeometry
private:
    GeosPolygon();
public:
%extend
    ~GeosPolygon()
%rename(GeometryCollection) GeosGeometryCollection;
class GeosGeometryCollection: public GeosGeometry
private:
    GeosGeometryCollection();
public:
%extend
    ~GeosGeometryCollection()
%rename(MultiPoint) GeosMultiPoint;
class GeosMultiPoint: public GeosGeometryCollection
private:
    GeosMultiPoint();
public:
%extend
    ~GeosMultiPoint()
%rename(MultiLineString) GeosMultiLineString;
class GeosMultiLineString: public GeosGeometryCollection
private:
    GeosMultiLineString();
public:
%extend
    ~GeosMultiLineString()
%rename(MultiLinearRing) GeosMultiLinearRing;
class GeosMultiLinearRing: public GeosGeometryCollection
private:
    GeosMultiLinearRing();
public:
%extend
    ~GeosMultiLinearRing()
%rename(MultiPolygon) GeosMultiPolygon;
class GeosMultiPolygon: public GeosGeometryCollection
private:
    GeosMultiPolygon();
public:
%extend
    ~GeosMultiPolygon()
// ==== Geometry Constructors ===========
%newobject createPoint;
%newobject createLineString;
%newobject createLinearRing;
%newobject createPolygon;
%apply SWIGTYPE *DISOWN {GeosCoordinateSequence *s};
%inline %{
GeosPoint *createPoint(GeosCoordinateSequence *s)
    GEOSCoordSeq coords = (GEOSCoordSeq) s;
    return (GeosPoint*) GEOSGeom_createPoint(coords);
GeosLinearRing *createLinearRing(GeosCoordinateSequence *s)
    return (GeosLinearRing*) GEOSGeom_createLinearRing(coords);
GeosLineString *createLineString(GeosCoordinateSequence *s)
    return (GeosLineString*) GEOSGeom_createLineString(coords);
GeosPolygon *createPolygon(GEOSGeom shell, GEOSGeom *holes, size_t nholes)
    return (GeosPolygon*) GEOSGeom_createPolygon(shell, holes, nholes);
%clear GeosCoordinateSequence *s;
%newobject createCollection;
GEOSGeom createCollection(int type, GEOSGeom *geoms, size_t ngeoms)
    return GEOSGeom_createCollection(type, geoms, ngeoms);
// === Input/Output ===
%newobject geomFromWKT;
%newobject geomFromWKB;
%inline %{
GeosGeometry geomFromWKT(const char *wkt)
    return (GeosGeometry) GEOSGeomFromWKT(wkt);
char *geomToWKT(const GeosGeometry* g)
    const GEOSGeom geom = (const GEOSGeom) g;
    return GEOSGeomToWKT(geom);
int setWKBOutputDims(int newDims)
    return GEOS_setWKBOutputDims(newDims);
GeosGeometry geomFromWKB(const unsigned char *wkb, size_t size)
    return (GeosGeometry) GEOSGeomFromWKB_buf(wkb, size);
unsigned char *geomToWKB(const GEOSGeom* g, size_t *size)
    return GEOSGeomToWKB_buf(geom, size);
