[Gdal-dev] need suggestions about TIFF image processing
    Maciek Sieczka
    werchowyna at epf.pl
    Wed Jun 28 13:17:53 EDT 2006
On Wed, 28 Jun 2006 12:42:20 +0200
"Zhonghai Wang" <zhonghaiw at gmail.com> wrote:
> Hi guys,
> I have about 200 RGB TIFFs (24bit) for my application, since the
> color is not so nice enough, I want to make some changes, therefore I
> need a software to do it, and even to convert the image format, such
> as TIFF to GIF.
gdal_translate, in a loop like this (using BASH on Linux, mind my
limited scripting skills but works, gifs will be stored in your
current dir):
#!/bin/bash
LIST=$(ls /the/dir/where/tiffs/are | grep -i ".tif")
#				adjust the extension as needed
for FILE in $LIST;
do
	echo
	echo Converting: $FILE
	# optional to convert all filenames to lowercase:
	# FILE_LOW=`echo $FILE | tr A-Z a-z`
done
> Both opensource and commercial software will do.
opensource is not contrary to commercial - take GDAL for example :).
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
