[Gdal-dev] Limit columns returned in OGR?
Craig Miller craig.miller at spatialminds.com
Wed Jun 28 15:37:53 EDT 2006
Is there a way to limit the columns that are returned with a layer other
than using OGRDataSource::ExecuteSQL(...)?
E.g.
OGRDatasource::GetLayer() allows me to set the SQL FROM clause to a single
table.
OGRLayer::SetAttributeFilter allows me to set the SQL WHERE clause.
I don't see it, but I thought I'd ask before I code something using
ExecuteSQL()... Is it possible to set the SQL SELECT clause?
Thanks,
Craig
