[Gdal-dev] need suggestions about TIFF image processing
Zhonghai Wang zhonghaiw at gmail.com
Thu Jun 29 02:52:05 EDT 2006
thank you guys for the suggestions. I've found a solution for my image
processing.
kind regards
zhonghai
On 6/29/06, Eric Dönges <eric.doenges at gmx.net> wrote:
> Am 28.06.2006 um 19:17 schrieb Maciek Sieczka:
> > On Wed, 28 Jun 2006 12:42:20 +0200
> > "Zhonghai Wang" <zhonghaiw at gmail.com> wrote:
> >> Hi guys,
> >> I have about 200 RGB TIFFs (24bit) for my application, since the
> >> color is not so nice enough, I want to make some changes, therefore I
> >> need a software to do it, and even to convert the image format, such
> >> as TIFF to GIF.
> > gdal_translate, in a loop like this (using BASH on Linux, mind my
> > limited scripting skills but works, gifs will be stored in your
> > current dir):
> If all you want to do is change image formats, you might also want to
> take a look
> at ImageMagick (http://www.imagemagick.org), which supports most
> (raster) image formats
> known to man, and allows you to do a large variety of image
> processing operations.
> Like GDAL, it is free software.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060629/170a4120/attachment.html
