[Gdal-dev] problem with ogr2ogr -f PostgreSQL...
Thom DeCarlo t.r.decarlo at larc.nasa.gov
Tue Mar 7 17:21:55 EST 2006
I've set up my PostGIS-enabled PostgreSQL database and created a dataset
called "spatial". I have several shapefiles that I want to load into a
single layer. I found the instructions on the gdal website but when I
specify a layername at the end of the ogr2ogr command it quietly fails. That
is, no messages of any kind either at the command line nor in the pgsql
logfile. If I don't specify a layername the command works just fine.
Are there known problems with this function? I'm using PostGIS 1.1.0 and
PostgreSQL 8.1.1 on RHEL3.
Thanks,
Thom
Thom DeCarlo
             Who is General Failure
         and why is he reading my disk?
