[Gdal-dev] problem with ogr2ogr -f PostgreSQL...
Ethan Alpert ealpert at digitalglobe.com
Tue Mar 7 18:33:19 EST 2006
Actually you need PGB:  NOT PG8:
I just dumped and inserted data using the CVS version of ogr with
postgres 8.1.3 and postgis 1.1.1
-e
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Chapman,
Martin
Sent: Tuesday, March 07, 2006 4:07 PM
To: Thom DeCarlo; gdal-dev at lists.maptools.org
Subject: RE: [Gdal-dev] problem with ogr2ogr -f PostgreSQL...
Thom,
Also, you will have to modify ogr2ogr to pass the PG8: connection prefix
instead of PG:.  When I look at the old code I don't know how it ever
worked.  Basically because the PG: prefix was never being stripped off
the connect string before being passed to the PG driver, and the PG
driver doesn't like the PG: prefix.  Maybe in pre 8.x versions I would
ignore the prefix.
Martin
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Thom DeCarlo
Sent: Tuesday, March 07, 2006 3:22 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] problem with ogr2ogr -f PostgreSQL...
I've set up my PostGIS-enabled PostgreSQL database and created a dataset
called "spatial". I have several shapefiles that I want to load into a
single layer. I found the instructions on the gdal website but when I
specify a layername at the end of the ogr2ogr command it quietly fails.
That
is, no messages of any kind either at the command line nor in the pgsql
logfile. If I don't specify a layername the command works just fine.
Are there known problems with this function? I'm using PostGIS 1.1.0 and
PostgreSQL 8.1.1 on RHEL3.
Thanks,
Thom
Thom DeCarlo
             Who is General Failure
         and why is he reading my disk?
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
