[Gdal-dev] rgb2pct.py error on geotiff from gdal_merge.py
Wed Mar 8 09:51:01 EST 2006
Ken-ichi wrote:
> Hi all,
> I'm having a problem that seems similar to bugs 329 and 975.  When I
> create a GeoTIFF using
> /usr/local/bin/gdal_merge.py -ps 5 5 -o test_mosaic.tif_tmp *_tmprgb
> and try to reduce to pseudocolor like
> /usr/local/bin/rgb2pct.py test_mosaic.tif_tmp test_mosaic.tif
> I get a whole slew of errors like this:
> ERROR 1: IReadBlock failed at X offset 0, Y offset 5031
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 5031
> ERROR 1: test_mosaic.tif_tmp:0: Invalid strip byte count, strip 133707
> ERROR 1: TIFFReadEncodedStrip() failed.
> Any thoughts, advice?  Or is this a bug?
Ken-ichi,
I think this is likely bug 975, which is fixed in CVS.  Try upgrading
to GDAL-cvs (or a nightly snapshot), and try rgb2pct.py again.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
