[Gdal-dev] OGRSpatialReference: delete/Dereference crashes under MS Visual Studio (GDAL 1.3.1)
Thu Mar 9 09:39:45 EST 2006
Pieter Bekaert wrote:
> While porting some code to Visual Studio, the following problem has
> occurred:
> Deleting (or dereferencing when the counter == 1) in our setup causes an
> exception to be thrown. This happens even with the following trivial
> piece of code:
> 	OGRSpatialReference* ogrsr = new OGRSpatialReference();
> 	delete ogrsr;
> I searched the bug list but didn't find anything relevant.
> We started from gdal131.zip and tried it with Visual Studio 2003.
> Any suggestions?
Pieter,
Do you know if you are using the same heap for your application code,
and OGR in this case?  For instance, are both compiled with /MD to
us MSVCRT.DLL (or modern equivelent)?
If not, then I suspect the problem relates to cross-heap issues.  The
solution would either be to use the C API instead of the C++ API or
to use alternate methods to create and destroy at least.
eg.
	OGRSpatialReference *ogrsrs = (OGRSpatialReference *)
                         OSRNewSpatialReference( NULL );
         OGRDestroySpatialReference( ogrsrs );
I realize it doesn't help anything, but at this point I would also
like to say that it is a *great* frustration to me that Microsoft
continues to propagate this whole "heap per DLL" paradyme which makes
it very hard to port C++ libraries from platforms compliant with the
C++ language standard.
I try to be platform agnostic, but windows consistently makes my life
a misery!
/me breathes deeply, and steps off the soapbox.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
