[Gdal-dev] ArcGrid to IMG conversion: huge file
Petteri Packalen packalen at cs.joensuu.fi
Thu Mar 9 11:40:42 EST 2006
More clarification about this IMAGINE nodata issue. IMAGINE prefers the
term BACKGROUND. It isn't strictly "notada" as we understand the concept.
Often zero is used as background value but it cannot be defined in
IMG-file (at least I haven't found such a functionality in 10+ years).
Many dialogs has an option "Ignore Zero in Stats" which serves a kind of
surrogate to nodata functionality. Some import dialogs allows user to
select whether "nodata" is converted to zero or e.g. minimum value of the
current datatype.
Best regards
Petteri
Petteri Packalén
University of Joensuu
Faculty of Forestry
P.O. Box 111
80101 Joensuu
Finland
e-mail: packalen at cs.joensuu.fi
On Thu, 9 Mar 2006, Thom DeCarlo wrote:
> Markus,
> The IMG format doesn't support the concept of "NODATA", and by default does
> not use compression. It does support ESRI-style run length encoding, but I
> haven't seen it used much. You might do better converting to geotiff which
> supports LZW compression and Frank has extended it to support a NODATA tag.
> Thom DeCarlo
>           Experience is a wonderful thing
> It allows you to recognize a mistake when you make it again.
>> -----Original Message-----
>> From: Markus Neteler
>> Sent: Thursday, March 09, 2006 6:04 AM
>> To: GDAL-dev list
>> Subject: [Gdal-dev] ArcGrid to IMG conversion: huge file
>> Hi,
>> when converting the
>>   Landscan Global Population 2000 Database
>> from
>>   http://www.fao.org/geonetwork/srv/en/metadata.show?id=1261
> [snip]
>> Apparently the NoData isn't passed to IMG.
>> Is the created IMG file probably uncompressed
>> which leads to this big file size?
>> Best regards
>>  Markus
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
