[Gdal-dev] ogr2ogr:floating point exception
Curt Mills archer at eskimo.com
Sun Mar 12 15:44:36 EST 2006
On Sun, 12 Mar 2006, marco wrote:
> I have a problem with ogr2ogr and ogrinfo, I build gdal on slackware linux
> 10.2 with 2.4 kernel an it works fine.
> When I've upgraded my kernel version to 2.6 ,the result executing ogrinfo or
> ogr2ogr is:floating point exception.
> I try to rebuild gdal under 2.6 kernel but it's the same.
I've seen this problem recently with an SuSE-10 installed gcc-4.xx
pre-release compiler and it went away by getting rid of some of the
compiler flags in CFLAGS, or by updating the compiler to a later
version.  I doubt that's your problem, but I figured I should
mention it.  The compiler identified itself with gcc-4.02
pre-release or something similar.
Curt, WE7U.				archer at eskimo dot com
http://www.eskimo.com/~archer
  Lotto:  A tax on people who are bad at math. - unknown
Windows:  Microsoft's tax on computer illiterates. - WE7U.
The world DOES revolve around me:  I picked the coordinate system!"
