[Gdal-dev] why does shape datasource count lone dbf files as layers?
Ari Jolma ari.jolma at tkk.fi
Mon Mar 13 16:17:07 EST 2006
Ari Jolma kirjoitti:
> I have data in shapefiles, which use dynamic segmentation. Thus (I
> believe) there are lone DBF files in the directory, which contain the
> "dynamic" data.
> Why does ogrshapedatasource.cpp:306-320 count these files as layers?
> The source code speaks about "without apparent associated shapefiles",
> in my case there are simply no associated shapefiles. The datasource
> is later unusable since the respective SHP files are not available and
> the program ends in error. I need to manually put these DBF files
> aside to be able to open the real layers.
To answer myself: this is a problem in the Swig interface. The error is
not supposed to be an error that is reported to the user, but it is
because it is there. The problem is in cpl_exceptions.i, which does not
work (at least) in this case. I don't know how to fix it right away.
Kevin, Charlie: this is probably also a bug in Python and Ruby
interfaces. The %exception should not just blindly test eclass but test
the return value from the function.
Ari
> Ari
Prof. Ari Jolma
Kartografia ja Geoinformatiikka / Cartography and Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
