[Gdal-dev] ogr and shapefiles trhough CVS
Didrik Pinte dpinte at itae.be
Thu Mar 16 06:47:53 EST 2006
I have a multi-plaform project working with openev and gdal/ogr.
Test files are in my CVS repository and seems to be broken when updated
on the Windows platform. They have been commited with -ko argument but
it doesn't change anything.
Here is the output of ogrinfo :
On Linux (Debian/Sid gdal 1.3.1) :
did at geru-itae:~/Documents/ucl/alert/python/alert/test/scenario2$ ogrinfo
polygones.shp
INFO: Open of `polygones.shp'
using driver `ESRI Shapefile' successful.
1: polygones (Polygon)
On Windows (XP with FWtools 1.0.9a - gdal 1.3.1 ):
C:\Program Files\FWTools1.0.0a9\bin>ogrinfo d:\ALERT\python\alert\test
\scenario2\polygones.shp
ERROR 1: Record count in .shp header is -12, which seems
unreasonable.  Assuming header is corrupt.
FAILURE:
Unable to open datasource `d:\ALERT\python\alert\test\scenario2
\polygones.shp' w
ith the following drivers.
  -> ESRI Shapefile
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> S57
  -> MapInfo File
  -> DGN
  -> VRT
  -> AVCBin
  -> REC
  -> Memory
  -> CSV
  -> GML
  -> Interlis 1
  -> Interlis 2
  -> SQLite
  -> ODBC
  -> PGeo
  -> OGDI
  -> PostgreSQL
  -> MySQL
How can I solve this problem ?
Didrik
Name: not available
Desc: Ceci est une partie de message
	=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060316/b3534e2d/attachment.bin
