[Gdal-dev] ogr and shapefiles trhough CVS
Didrik Pinte dpinte at itae.be
Thu Mar 16 09:20:41 EST 2006
Le jeudi 16 mars 2006 à 08:41 -0500, Frank Warmerdam a écrit :
> Didrik Pinte wrote:
> > Hi,
> > I have a multi-plaform project working with openev and gdal/ogr.
> > Test files are in my CVS repository and seems to be broken when updated
> > on the Windows platform. They have been commited with -ko argument but
> > it doesn't change anything.
> Didrik,
> When storing binary files in CVS you should also set the -kb flag or
> else CVS may try and apply DOS/unix text conversion on the fly.
> Best regards,
Hi Frank,
I've deleted the files from the repositories, then add them with -kb and
-ko but the problem stays.
I've tried the following : copy by scp the files from the same directory
on the linux laptop to the windows one --> ogrinfo works well. It's
definitely a problem of CVS but wich one ...
Sorry for polluting gdal-dev with such question.
Didrik
Name: not available
Desc: Ceci est une partie de message
	=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060316/6eae3b22/attachment.bin
