[Gdal-dev] gdal warp code silently skipping datum shift
John Johnson jdjohnso at google.com
Fri Mar 17 14:09:51 EST 2006
> Potentially I could accomplish this in the
> OGRCreateCoordinateTransformation()
> function.  Possibly adding a flag indicating if missing datum shifts
> should
> be:
>   - handled as currently (quietly convert just based on ellipsoid)
I understand your desire to be able to preserve existing functionality, but
would this approach ever give correct results?
 If you would like to file a bug report on this issue, I can try and queue
> up a work item.
Will do.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060317/09450dd2/attachment.html
