[Gdal-dev] Percent complete and jpeg driver
Tue Mar 21 14:47:45 EST 2006
Garrett Potts wrote:
> Hello All:
> I am using the progress function and have abort support.  When aborting
> I return a value of 0 from the progress function and this does stop GDAL
> CreateCopy from executing further.  For the jpeg driver it calls exit
> internally since it was not able to read enough data.  Is there a way to
> trap this through GDAL so it doesn't call exit but instead errors out
> gracefully?
Garrett,
I have corrected the CreateCopy() in jpgdataset.cpp to *not* call
jpeg_finish_compress() if any sort of error (including user termination)
occurs and now interruption should cleanup and return gracefully.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
