[Gdal-dev] Percent complete and jpeg driver
Garrett Potts potts at cfl.rr.com
Tue Mar 21 14:53:07 EST 2006
Hello Frank:
Just updated the jpeg driver and tested the abort and it works great
now.  Thank you again.
Take care
Garrett
On Mar 21, 2006, at 2:47 PM, Frank Warmerdam wrote:
> Garrett Potts wrote:
>> Hello All:
>> I am using the progress function and have abort support.  When
>> aborting I return a value of 0 from the progress function and this
>> does stop GDAL CreateCopy from executing further.  For the jpeg
>> driver it calls exit internally since it was not able to read
>> enough data.  Is there a way to trap this through GDAL so it
>> doesn't call exit but instead errors out gracefully?
> Garrett,
> I have corrected the CreateCopy() in jpgdataset.cpp to *not* call
> jpeg_finish_compress() if any sort of error (including user
> termination)
> occurs and now interruption should cleanup and return gracefully.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGF, http://
> osgeo.org
