[Gdal-dev] Mishandled "pixel is point" in geotiff
Tim Beckmann tbeckman at usgs.gov
Tue Mar 21 16:48:38 EST 2006
Frank,
I understand.  I went through the same denial and some confusion several
years ago when I first ran into the issue.
Unfortunately, feeding the -a_ullr parameter corner points based on
pixel-is-area results in an output file only works properly if you want
the output geotiff to be pixel-is-area.  We typically create geotiff files
using pixel-is-point and don't really have the freedom to change that. So,
I'll probably have to maintain my little hack separately until you "cave
in and fix it" ;).
I guess another option might be to change things to feed it pixel-is-area
corner points and change the hack to instead adjust the ModelTiePointTag
values written by 0.5 pixels if the pixel-is-point metadata tag is set.  I
think that would allow the rest of gdal to work as expected, but still
produce an output geotiff with accurate data for the pixel-is-point case.
(probably wouldn't work for reading that geotiff back into gdal though).
If you wanted to include something like that in gdal, I could be convinced
to create a patch for it.  Not a complete solution by any means, but
perhaps a step in the right direction.
Thanks
Tim
Tim Beckmann
Software Project Lead
Science Applications International Corporation (SAIC)
Contractor to the USGS/EROS
Sioux Falls, SD 57198
605-594-2521    Phone
605-594-6940    Fax
Frank Warmerdam <warmerdam at pobox.com>
Sent by: Frank Warmerdam <fwarmerdam at gmail.com>
03/21/2006 03:28 PM
To
Tim Beckmann <tbeckman at usgs.gov>
cc
gdal-dev at lists.maptools.org
Subject
Re: [Gdal-dev] Mishandled "pixel is point" in geotiff
Tim Beckmann wrote:
> Hi all (and Frank),
> I sent an email to the list a few weeks ago about geotiff files with the
> "Pixel is point" option not being handled properly by gdal.  I only
> received a reply from one person off the list stating that it was a
known
> problem.
> I did figure out how to pass the "-mo AREA_OR_POINT=POINT" parameter to
> gdal_translate to tell it to include the pixel is point indication in
the
> output geotiff file.  So, my command line looks like:
>         gdal_translate -mo AREA_OR_POINT=POINT -co INTERLEAVE=PIXEL \
>                 -a_srs "+proj=utm +zone=15 +datum=WGS84"  \
>                 -a_ullr 753600 3462900 801900 3260100 \
>                 'HDF4_SDS:UNKNOWN:"EO1H0220392005002110P0_HDF.L1T":0'
> testit_b001.tif
> This results in the geotiff file properly indicating "pixel is point".
> However, the reported pixel size is incorrect.  It is being calculated
> incorrectly from the provided corners like it was still "pixel is area"
> (so instead of being 30 meters, it is just a little less than 30
meters).
> The hack at the bottom of the email works around it by rescaling the
pixel
> size for the "pixel is point" case.  But it doesn't do anything for
> properly fixing the issue throughout gdal... (but it looks like the
"pixel
> is point" support itself is a hack...)
Tim,
I'm not completely out of denial about PixelIsPoint.  At some point I will
finally cave in and fix it, but it will need to be addressed in a variety
of places in the software.  In the meantime you need to specify -a_ullr
based
on the implicit pixel-is-area assumption of GDAL.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
