[Gdal-dev] One band Jpeg with color table
Wed Mar 22 21:29:36 EST 2006
Ivan Lucena wrote:
> Hi There,
> Maybe it's because I am new here, so my questions could be silly.
> But f you have a single band byte image with color table and you want to
> export to a jpeg color result, for visualization purpose only, you need
> to create a RGB version of your image and then convert it to jpeg,
> because jpeg single band are greyscale only
> (http://www.gdal.org/frmt_jpeg.html).
> How to do that in the GDAL C API?
Ivan,
There is no built in support for this operation.  You basically need to do
it for yourself "in code" if you are using the library.  For commandline
purposes there is an existing pct2rgb.py script that can be used.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
