[Gdal-dev] OGRGeometry::Distance()
Sean Gillies sgillies at frii.com
Mon Mar 27 09:32:46 EST 2006
On Mar 26, 2006, at 9:13 PM, Frank Warmerdam wrote:
> Danilo Sanchi wrote:
>> Hi,
>> Could you say me if is possible to use the method Distance() of
>> OGR geometry class at this moment? How can do to run it?
>> I understand that this method use the GEOS library to run, but OGR
>> at now do not include the Geos version that implement this
>> functionallity correctly.
> Danilo,
> When GDAL is built against the GEOS C API it does not currently
> provide the Distance operation since the original version of the C API
> did not include this.
> If you are currently using the GEOS C API and would prefer to use
> the C++
> API of GEOS to enable distance support, you can modify the line in the
> gdal/GDALmake.opt file that says "HAVE_GEOS = c_api" to read instead
> "HAVE_GEOS = yes".  (this is for unix or linux).
> Best regards,
FYI, I've added distance to the GEOS C API in CVS, and it will be out
in the 2.2.2 release.
Sean
Sean Gillies
http://zcologia.com
