[Gdal-dev] Bug in OGDI Driver when accessing tiles (FAILURE: 1: End of selection)
Reiner Beck r.beck at m4com.de
Tue Mar 28 09:03:10 EST 2006
(2nd try - the first one went to gdal-dev at remotesensing.org - sorry if
you receive this twice)
Hello List,
there seems to be a bug in the OGDI driver when accessing tiles which
are directly "under" the previously fetched tile.
Here's what I do:
- The driver is a RPF dataset and the sub-dataset used is a Matrix layer.
  This is a layer with a colortable, not the RGB Image layer.
- The error does only occur for single band access.
- I read the image data tile by tile using the
GDALRasterBand::RasterIO() method.
- For example, the Image Size is 6144x3072, Tile Size is 256x256, No of
Tiles is 24x12.
- For internal reasons, the tiles are fetched somewhat randomly.
- The error occurs only in case a tile is read, followed by a read to a
tile which is directly
  under the previously read tile.
Example:
First tile to read is [3, 7]:
This results in calls to:
  poBand->RasterIO(GF_Read, 768, 1792, 256, 256, poinerToMyBuffer, 256,
256, 1, 1, 256);
and GDAL internal to
  OGDIRasterBand::EstablishAccess(768, 1792, 256, 256, 256, 256);
Let's assume this works.
Next tile to read is [3, 8]:
  poBand->RasterIO(GF_Read, 768, 2048, 256, 256, poinerToMyBuffer, 256,
256, 1, 1, 256)
  OGDIRasterBand::EstablishAccess(768, 2048, 256, 256, 256, 256);
In this case, the method EstablishAccess() will not call
cln_SelectRegion() and the read will fail with an error 1 "End of
selection". This happens in the OGDI RPF driver, function
dyn_getNextObjectRaster(). However, I think the error is in the GDAL part.
Workaround:
In case the if statement in EstablishAccess() is commented out (not the
body of the statement), it works:
/if( poODS->nCurrentIndex == -1 / / || ABS(sWin.west -
poODS->sCurrentBounds.west) > 0.0001 / / || ABS(sWin.east -
poODS->sCurrentBounds.east) > 0.0001 / / || ABS(sWin.north -
(poODS->sCurrentBounds.north - poODS->nCurrentIndex *
poODS->sCurrentBounds.ns_res)) > dfNSTolerance / / ||
ABS(sWin.ew_res/poODS->sCurrentBounds.ew_res - 1.0) > 0.0001/ / ||
ABS(sWin.ns_res - poODS->sCurrentBounds.ns_res) > dfNSTolerance )/ /
Not sure if this is the best solution though ...
Version:
gdal 1.2.6 and ogdi 3.1.4. However, the affected code seems to be
identical to the most recent versions (checked against gdal 1.3.1 and
ogdi 3.1.5).
Cheers
Reiner
