[Gdal-dev] RE: [postgis-users] Adding to Spatial Ref Sys table
Wed Mar 29 20:45:31 EST 2006
Craig Miller wrote:
> Note:  This thread started on the postgis list.  I moved it here since this
> tangent is gdal specific.
> Frank,
> It appears the the pg driver uses the wkt definition primarily in the
> FetchSRSId method.  It would be trivial to just add the proj definition
> along with the wkt definition in this section.  I'll take a look at it
> tomorrow, add it, and submit the code along with the bug.
Even better!
You are correct that the WKT as it is, can still be of use to OGR.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
