[Gdal-dev] Error compiling gdal with MrSid support in ubuntu linux
Thu Mar 30 17:09:20 EST 2006
Mikael Schröder wrote:
> Perfekt!
> Thank you!!! It finally worked!
> I will give the ecw-problem a try another day/night... (now that I got
> MrSid working)
> With "other C++ packages" you refer only to packages that depend upon
> libgeos/libgdal right. like Qgis, mapserver etc.
> What about PostGIS ??
Mikael,
I meant any other library for which GDAL, mapserver, etc use a C++
interface.  In your context the obvious candidates are mrsid, ecw, geos,
gdal/ogr, mapserver and gqis.  But there might be other packages that could
be an issue.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
