[Gdal-dev] gdalwarp Corine
Mon May 1 10:44:01 EDT 2006
Dieter Lehmann wrote:
> Hello Armin,
> thanks for your replay.
> I found, that my tfw was not correct (first line was corrupt), after I
> changed
> that, I get a new error, either I tryed the EPSG-code or the full
> description
> of it.
> Any ideas?
> Here's the error I got:
> ERROR 1: latitude or longitude exceeded limits
> ERROR 1: GDALWarperOperation::ComputeSourceWindow() failed because the
> pfnTranformer failed.
Dieter,
The error means at some stage in the transformations a latitude or
longitude exceeded the -360 to 360 range for longitude or more likely the
-90 to 90 range for latitude.
If you can provide the file you are attempting to transform I could try and
reproduce your problem.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
