[Gdal-dev] HDF file support
Tue May 2 10:48:09 EDT 2006
salah jubeh wrote:
> but the strange thing is that if the HDF file resides in the same PC i
> get no error
Salah,
There are two possibilities.  One is that all the extra filename parsing
done for HDF files (to separate the various parts of the subdataset) are
getting confused by the backslashes or the double backslash.  The other
possibility is that the underlying HDF IO functions don't support the
network drive naming mechanism you used.  If the issue were the first
one, I could look into fixing it.  If it is the second then there isn't
really much I can do about it.
I would encourage you to just keep the files local, or perhaps on a
conventionally mounted network drive (with a drive letter assigned).
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
