[Gdal-dev] Re: ruby bindings not compiling from CVS
Howard Butler hobu at iastate.edu
Tue May 2 14:09:46 EDT 2006
Here's the latest buildbot results for "make generate" in the swig
directory.
<http://gdal.builds.hobu.net/macosx-darwin-tiger-10.4.5/builds/85/step-shell_5/0>
Ruby doesn't get generated here (this is macosx) because the ruby
bindings must depend on a version of swig later than 1.3.27.
There was some makefile reconfiguration that went on a couple of
weeks ago.  Could that be the culprit?
Howard
At 12:45 PM 5/2/2006, Charlie Savage wrote:
>Don't have a Mac.  I'll try to take a look at windows and linux,
>maybe the problem occurs there also.
>Charlie
>Ken-ichi wrote:
>>No, no errors during the compilation, and no mention of 'ruby'
>>whatsoever during the same.  I take it you are unable to reproduce
>>this problem?
>>Ken-ichi Ueda
>>Kelly Research and Outreach Lab (http://kellylab.berkeley.edu)
>>University of California, Berkeley
>>Environmental Science, Policy, and Management
>>Berkeley, CA 94720
>>tel: 510.642.8322
>>fax: 510.642.1477
>>e-mail: kueda at nature.berkeley.edu
>>>Any error messages in the compiling stage?
>>>Charlie
>>>Ken-ichi wrote:
>>>>Hi Charlie,
>>>>Nope, the extension never gets built.  The only things in
>>>>swig/ruby are the sources and makefiles.
>>>>Ken-ichi Ueda
>>>>Berkeley, CA 94720
>>>>tel: 510.642.8322
>>>>fax: 510.642.1477
>>>>>Hi Ken-ichi,
>>>>>Is the extension successfully built?  IE., is there a gdal.so
>>>>>file in the swig/ruby directory?
>>>>>Charlie
>>>>>     Ken-ichi wrote:
>>>>>>Hi all,
>>>>>>When I try to compile the latest CVS (4.30.06) version of GDAL
>>>>>>--with-ruby, configuring and compiling go off without a hitch,
>>>>>>but when I try to make install, I get this error:
>>>>>>(cd swig; make install)
>>>>>>for dir in ruby ; do (cd $dir; make install ); done
>>>>>>make -f RubyMakefile.mk install
>>>>>>/bin/sh /usr/local/src/gdal-cvs-2006.04.30/libtool
>>>>>>--mode=install /usr/local/src/gdal-cvs-2006.04.30/install-sh -c
>>>>>>gdal.so ogr.so gdalconst.so osr.so
>>>>>>/usr/darwinports/lib/ruby/site_ruby/1.8/powerpc-darwin8.6.0/gdal
>>>>>>/usr/local/src/gdal-cvs-2006.04.30/install-sh -c gdal.so
>>>>>>/usr/darwinports/lib/ruby/site_ruby/1.8/powerpc-darwin8.6.0/gdal/gdal.so
>>>>>>install:  gdal.so does not exist
>>>>>>make[3]: *** [install] Error 1
>>>>>>make[2]: *** [install] Error 2
>>>>>>make[1]: *** [install] Error 2
>>>>>>make: *** [install-actions] Error 2
>>>>>>It doesn't look like gdal.so is getting made at all.  I'm
>>>>>>getting basically the same error on Mac OS 10.4 and Gentoo
>>>>>>Linux.  I do not get this error on Gentoo with the 1.3.1 source
>>>>>>(haven't tried that one on my Mac yet).
>>>>>>Any thoughts?
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
