[Gdal-dev] Re: ruby bindings not compiling from CVS
Charlie Savage cfis at interserv.com
Tue May 2 15:39:58 EDT 2006
Should we all agree to use the same version of SWIG?  I'd vote 1.3.29,
but could live 1.3.28.  1.3.27 is not as good because it doesn't support
automatic renaming of Ruby functions from camelCase to
lower_case_with_underscores.  I can work around that using a rename.i
file, but I was so happy to be able to get rid of that :)
Charlie
Ari Jolma wrote:
> Charlie Savage kirjoitti:
>> The error on the build box is that the -autorename SWIG switch is in
>> SWIG 1.3.28 and higher.
>> Thought Ari upgraded Perl to use SWIG 1.3.29?  The current CVS ruby
>> swig wrapper cxx files are from 1.3.28 if I remember correctly.  Any
>> reason not to use those as opposed to generating new ones when building?
> I guess
> make[1]: Nothing to be done for `generate'.
> is from dir=perl in that log. Otherwise I don't know what's
> happening... The perl bindings also require very recent swig.
> Ari
>> What were the changes in the makefiles that might cause issues?
>> Charlie
>> Howard Butler wrote:
>>> Here's the latest buildbot results for "make generate" in the swig
>>> directory.
>>> <http://gdal.builds.hobu.net/macosx-darwin-tiger-10.4.5/builds/85/step-shell_5/0>
>>> Ruby doesn't get generated here (this is macosx) because the ruby
>>> bindings must depend on a version of swig later than 1.3.27.
>>> There was some makefile reconfiguration that went on a couple of
>>> weeks ago.  Could that be the culprit?
>>> Howard
>>> At 12:45 PM 5/2/2006, Charlie Savage wrote:
>>>> Don't have a Mac.  I'll try to take a look at windows and linux,
>>>> maybe the problem occurs there also.
>>>> Charlie
>>>> Ken-ichi wrote:
>>>>> No, no errors during the compilation, and no mention of 'ruby'
>>>>> whatsoever during the same.  I take it you are unable to reproduce
>>>>> this problem?
>>>>> Ken-ichi Ueda
>>>>> Kelly Research and Outreach Lab (http://kellylab.berkeley.edu)
>>>>> University of California, Berkeley
>>>>> Environmental Science, Policy, and Management
>>>>> Berkeley, CA 94720
>>>>> tel: 510.642.8322
>>>>> fax: 510.642.1477
>>>>> e-mail: kueda at nature.berkeley.edu
>>>>>> Any error messages in the compiling stage?
>>>>>> Charlie
>>>>>> Ken-ichi wrote:
>>>>>>> Hi Charlie,
>>>>>>> Nope, the extension never gets built.  The only things in
>>>>>>> swig/ruby are the sources and makefiles.
>>>>>>> Ken-ichi Ueda
>>>>>>> Berkeley, CA 94720
>>>>>>> tel: 510.642.8322
>>>>>>> fax: 510.642.1477
>>>>>>>> Hi Ken-ichi,
>>>>>>>> Is the extension successfully built?  IE., is there a gdal.so
>>>>>>>> file in the swig/ruby directory?
>>>>>>>> Charlie
>>>>>>>>     Ken-ichi wrote:
>>>>>>>>> Hi all,
>>>>>>>>> When I try to compile the latest CVS (4.30.06) version of GDAL
>>>>>>>>> --with-ruby, configuring and compiling go off without a hitch,
>>>>>>>>> but when I try to make install, I get this error:
>>>>>>>>> (cd swig; make install)
>>>>>>>>> for dir in ruby ; do (cd $dir; make install ); done
>>>>>>>>> make -f RubyMakefile.mk install
>>>>>>>>> /bin/sh /usr/local/src/gdal-cvs-2006.04.30/libtool
>>>>>>>>> --mode=install /usr/local/src/gdal-cvs-2006.04.30/install-sh
>>>>>>>>> -c gdal.so ogr.so gdalconst.so osr.so
>>>>>>>>> /usr/darwinports/lib/ruby/site_ruby/1.8/powerpc-darwin8.6.0/gdal
>>>>>>>>> /usr/local/src/gdal-cvs-2006.04.30/install-sh -c gdal.so
>>>>>>>>> /usr/darwinports/lib/ruby/site_ruby/1.8/powerpc-darwin8.6.0/gdal/gdal.so
>>>>>>>>> install:  gdal.so does not exist
>>>>>>>>> make[3]: *** [install] Error 1
>>>>>>>>> make[2]: *** [install] Error 2
>>>>>>>>> make[1]: *** [install] Error 2
>>>>>>>>> make: *** [install-actions] Error 2
>>>>>>>>> It doesn't look like gdal.so is getting made at all.  I'm
>>>>>>>>> getting basically the same error on Mac OS 10.4 and Gentoo
>>>>>>>>> Linux.  I do not get this error on Gentoo with the 1.3.1
>>>>>>>>> source (haven't tried that one on my Mac yet).
>>>>>>>>> Any thoughts?
>>>> _______________________________________________
>>>> Gdal-dev mailing list
>>>> Gdal-dev at lists.maptools.org
>>>> http://lists.maptools.org/mailman/listinfo/gdal-dev
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060502/90651fa8/smime.bin
