[Gdal-dev] tiff creation with a colormap ?
Fri May 5 12:57:06 EDT 2006
Didrik Pinte wrote:
> Hi,
> Little technical question. I have (x,y,z) raster that i'm outputting to
> a GeoTiff file with the following code :
> driver_options = ['TFW=YES' 'COMPRESS=DEFLATE']
> dst_ds = driver.Create( filename, len(self.idx['X']),\
>                             len(self.idx['Y']), 1, gdal.GDT_Byte,\
>                             driver_options )
> [... coord sys lines ...]
> dst_ds.GetRasterBand(1).WriteArray( numpy.transpose(raster) )
> This creates a great raster in levels of gray.
> Used to matplotlib, how can I output this raster with a colormap [1]? Do
> I have to generate three bands ?
Didrik,
Create a gdal.ColorTable object and then write it with SetRasterColorTable()
on the band.   Makeu sure you do this right after the create, and before
writing the raster data or else it will be too late.
Without testing, this might look something like:
                             driver_options )
  ct = gdal.ColorTable()
  for i in range(256):
    ct.SetColorEntry( i, (255, 255 - i, i, 255) )
  dst_ds.GetRasterBand(1).SetRasterColorTable( ct )
The tuple passed to SetColorEntry() holds Red,Green,Blue,Alpha values.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
