[Gdal-dev] gdalwarp: Translating source or target SRS failed
Fri May 5 12:58:45 EDT 2006
Jachym Cepicky wrote:
> Hallo,
> I try to reproject some raster files using gdalwarp:
> gdalwarp -s_srs "+proj=krovak +lat_0=49.5 +lon_0=24.83333333333333 +alpha=30.28813972222222 +k=0.9999 +x_0=0  +y_0=0 +ellps=bessel +units=m +towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56" -t_srs "+proj=latlong +datum=WGS84" teplota.tif teplota-wgs.tif
> ERROR 1: Translating source or target SRS failed:
> When I use cs2cs for signle coordinates pair, it works great:
> echo "-868208.53      -1095793.57"| cs2cs  +proj=krovak +lat_0=49.5
> +y_0=0 +ellps=bessel +units=m +no_defs
> +towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56 +to +proj=latlong
> +datum=WGS84
> 12d48'25.16"E   49d27'8.146"N 46.959
Jachym,
It seems that the PROJ.4 -> Well Known Text translation code in
OGR is missing the Krovak case.  I will add it but this fix has
missed the GDAL 1.3.2 release.
... work, work, work ...
OK, it's in CVS now.
Note, you can put something like the following in a text file,
and reference that in your gdalwarp command to get Krovak support
without my fix.
PROJCS["Krovak",
     GEOGCS["Bessel 1841",
         DATUM["D_unknown",
             SPHEROID["bessel",6377397.155,299.1528128]],
         PRIMEM["Greenwich",0],
         UNIT["Degree",0.017453292519943295]],
     PROJECTION["Krovak"],
     PARAMETER["latitude_of_center",49.5],
     PARAMETER["longitude_of_center",24.83333333333333],
     PARAMETER["scale_factor",0.9999],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",0],
     UNIT["Meter",1]]
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
