[Gdal-dev] Compiler errors in 1.3.2 on windows
Joaquim Luis jluis at ualg.pt
Sat May 6 22:35:12 EDT 2006
When compiling on windows (VC6) I got the following errors.
Removing the offending repeated 'int i' declarations solved the problem.
Joaquim Luis
        cl /nologo /MD /EHsc /Ox -I..\..\port -I..\..\ogr -I..\..\gcore
-I..\..
\alg -D_USE_MATH_DEFINES /c idrisiDataset.cpp
idrisiDataset.cpp
idrisiDataset.cpp(825) : error C2374: 'i' : redefinition; multiple
initialization
        idrisiDataset.cpp(727) : see declaration of 'i'
idrisiDataset.cpp(1082) : error C2374: 'i' : redefinition; multiple
initialization
        idrisiDataset.cpp(1079) : see declaration of 'i'
idrisiDataset.cpp(1397) : error C2374: 'i' : redefinition; multiple
initialization
        idrisiDataset.cpp(1379) : see declaration of 'i'
idrisiDataset.cpp(1475) : error C2374: 'i' : redefinition; multiple
initialization
        idrisiDataset.cpp(1466) : see declaration of 'i'
NMAKE : fatal error U1077: 'cl' : return code '0x2'
Stop.
