[Gdal-dev] Compiler errors in 1.3.2 on windows
Sun May 7 15:12:09 EDT 2006
Joaquim Luis wrote:
> Frank,
> Thanks.
> I built GDAL with ECW & MrSID support and as far as gdalinfo respects
> things seams to be ok.
> But now I want to integrate this options in my Matlab code and have a
> question about these formats
> that I never used before (well I ocasionally loaded MrSID and ECW files
> with 3rth party softs).
> Are they allways georeferenced or are they used for both "generic"
> images and georeferenced images?
> The thing is that depending on each case I need to treat it on different
> sections of my code.
Joaquim,
Both MrSID and ECW can hold raw (ungeoreferenced) imagery.
Generally speaking GetGeoTransform() should return CE_Failure if there is
no meaningful geotransformation information for a dataset.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
