[Gdal-dev] Grid based transformation with ogr2ogr
uwe.schmitz at lverma.nrw.de uwe.schmitz at lverma.nrw.de
Thu May 11 02:55:44 EDT 2006
Frank,
> Uwe,
> I must appologising for not noticing/commenting on another issue.  If
> you expand +init=epsg:31467 it looks like:
>    +proj=tmerc +lat_0=0 +lon_0=9 +k=1.000000 +x_0=3500000 +y_0=0
>       +ellps=bessel +datum=potsdam +units=m +no_defs
> The +no_defs part actually means no defaults, but it is implemented
> by ignoring all items that come after it.  So I believe that the
> +towgs84= clause is being ignored by one or both of ogr2ogr and
> cs2cs.  To ensure you control the settings you should provide the
> definition directly instead of using the +init mechanism.
> eg.
>       +ellps=bessel +towgs84=631,23,451 +units=m +no_defs
> I also discovered that you do *not* want to use +datum=potsdam or
> else the internal PROJ.4 towgs84 definition for potsdam will
> take over.
> I must confess this stuff isn't as obvious as it ought to be!
Ok, now it works as expected! Our discussion clarifies
some things for me.
Many thanks for your help!
Uwe
